Leaking auxiliary valve assembly
   / Leaking auxiliary valve assembly #1
Det17
M4900
Kubota M4900 auxiliary valve is leaking hydraulic fluid. I accidentally hit the control arm of my remote valve. It stuck on while there was nothing hooked up to it. Mit started leaking Hydraulic fluid. It looked like the cover on the bottom may have had a seal or gasket on it. I removed it's and it just had a spring and a set nut. On further checking I found it is leaking from midway of the housing. Is there a gasket or seal? What is the best way to get to it? It only leaks while tractor is running. What's the best any to get to it? Thanks.
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
2021 JOHN DEERE 7R230 LOT NUMBER 204 (A53084)
2021 JOHN DEERE...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
JOHN DEERE 648R LOT NUMBER 105 (A53084)
JOHN DEERE 648R...
2010 Chevrolet HHR SUV (A51694)
2010 Chevrolet HHR...
