Leakdown of the bucket tilt cylinders..
   / Leakdown of the bucket tilt cylinders.. #1
Shada
Cedar Rapids, IA
hi,
issue 1)my 5500 will not start with a new battery
i checked a relay
it clicks when i turn key on.but my glow plug light does not work or anything else
issue2)i have been having a problem with leakdown of the bucket tilt cylinders
happy to be on tractorbynet and to share issues with u people...
help me
   / Leakdown of the bucket tilt cylinders.. #2
hi,
i checked a relay
help me
Shada,
New Battery, relay clicking equals a battery that is not charged good enough to turn your stater over or is not making a good connection.
Tilt cylinder leak.......how fast is it leaking down? Is it under load? Does it leak down when emtpy?
hugs, Brandi
Leakage is continuous with out load there is Leakage.
   / Leakdown of the bucket tilt cylinders.. #4
Check and clean your ground on both the battery and tractor frame.
The leak down on the cylinder can be isolated to either the cylinders or the valve body.
To find out which one it is raise your bucket up off the ground and disconnect the tilt cylinder quick coupler hoses.
If it leaks down then you know it is a cylinder if it does not leak when the hoses are disconnected then you know it is a valve issue.
   / Leakdown of the bucket tilt cylinders.. #5
About a month ago my tractor woulnt start and it turnned out that my starter had wet trash in the brush area of the starter. When it was very cold the trash would freeze and not allow the starter to work properly. When it was warm out it would turn over just fine.
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
7' Bush Hog 3 pt Mower (A50515)
7' Bush Hog 3 pt...
2019 KENWORTH T680 SLEEPER (A52577)
2019 KENWORTH T680...
2015 Ford Transit 350HD Passenger Van (A50323)
2015 Ford Transit...
2011 Ford F450 Bucket Truck (A47384)
2011 Ford F450...
John Deere 7000 12R 30" Planter (A50515)
John Deere 7000...
