Leak at connector
   / Leak at connector #1
GICE
Lebanon TN
John Deere 2520
My quick disconnect on a hydraulic line to the loader leaks from it's center. I have cleaned it but no success still leaks. Will replacing it be the best idea? Will I need to bleed the hydraulic line after the connector is replaced, if so how? Loader on a J.D. 2520 2.5 years old.
   / Leak at connector #2
Is the leak when connected or disconnected?
If when connected their are O-ring seals in the female half that can be replaced.
If when unconnected yes you will have to replace that half of the connector & no you should not need to do anything special to bleed the system. Just cycle the cylinders through full travel a few times should purge any air.
2012 DRAGON 8,400 GAL TRAILER (A53843)
2012 DRAGON 8,400...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
HURRICANE 6' X 11' CONTAINER (A51248)
HURRICANE 6' X 11'...
TOTE OF CONCENTRATED METAL CLEANER WITH HOSE AND DIAPHRAM PUMP (A53843)
TOTE OF...
2012 Tiger 130BBL Vacuum Trailer (A53117)
2012 Tiger 130BBL...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
