Leaf Sweeper Recommendation
   / Leaf Sweeper Recommendation #1
jamiebolseth
I bought a new 12 acre property (about 4 in lawn) with lots of oak trees (also elms, bass woods, maples, ash, etc). I'm anticpating the leaf raking season and was hoping that somebody would recommend a good lawn swweper. Of course I've looked at (and used) the stuff at Sears and Home Depot, but I was wondering if there are better, commercial grade sweepers out there.
JamieB
   / Leaf Sweeper Recommendation #2
Jamie,
Thats going to be a lot of leaves. I would forgo the sweeper and get a power bagger. Power baggers shred the leaves allowing more run time between dumps and a lot less of a pile when done. YMMV.
   / Leaf Sweeper Recommendation #3
Use to have a sweeper, sold it and bought a vacuum. The sweeper filled in about 2 minutes - seriously. One pass through the yard and it was done. For leaves, you need to chop 'em and vacuum up. Get a unit that pulls behind your mower and dumps easilly. My Agrifab is nice, but doesn't tilt enough to dump and also the construction of the box tends to hold the choppings in so that you have to use a rake or get right into it to get it empty. Other manufacture's units really tilt, some almost 90 degrees, to dump easily.
   / Leaf Sweeper Recommendation #4
do a google search for cyclone rake. or just search here at tbn. several members have them and there are some comments. search all posts for maximum results.
   / Leaf Sweeper Recommendation #5
get a trac Vac I have had three Currently own Two now. One We use for grass clippings it holds Two 32 Gallon Trash Cans and mount on our three point . The second is a Trac Vac 1080
11hp holds 50 bushel of shredded leaves. We have 6 acres we care for. Usually do about thirty loads a year. The size of the Trac Vac will depend on the size of tractor and mower deck you have. I started with a 580 5hp. when I owned as smaller Tractor Now I Have a New Holland TC33 D with a sixty inch MMM . Had a Kubota B-24 in between with a 54 inch deck and that when I found out I needed a bigger Vac, A 54 inch deck puts out to much for the smaller vacs to handle.
I,ve seen many makes of vacs ,But in my opinion Trac Vac Makes the best been using them for fifteen plus years. They are not cheap but you get what you pay for.
   / Leaf Sweeper Recommendation #6
Hi all, I just bought A JD X485 and also got the 3 bag 14 bushel power flow collection system. I dont have 12 acres to clean only 2 with several large maples and walnut trees. Im hoping this deal will work for me. Im 38yrs old and have been hand raking this yard since I was 13 (bought the house from my parents) and I have had enough. Good luck.
Adios , Mike
   / Leaf Sweeper Recommendation #7
I use a trac vac 880 behind a TC30. You can also order a extension hose (15 ft) to work around trees and flower beds. Just got the trac vac this year, used it on some of last years leaves and general mowing in the orchard. Works great. Dumping was a problem at first, until I realized the best (for me) way was to dump, then ease forward a few feet. Everything dumps. Trac vacs are made heavy duty. Mine holds 50 cubic feet. You can buy some models setup so the motor mounts to your 3ph, others like mine mount on the dump trailer.
   / Leaf Sweeper Recommendation #8
I have a cyclone rake which has features such as its a great unit for storing as the motor comes off , folds up flat and really holds alot of leaves. There is one problem with it though and that is asyour catching leaves and grass the fine debrey will blow up thru the vent in the top and eventually you are full of fine dust. Check out the DR rake which they didn't make when I bought my cyclone. Earl
   / Leaf Sweeper Recommendation #10
I have always used the powerflo bagger with my John Deeres to collect leaves. Works well as long as you mow regularly. Last year I tried Gator blades. They really work. They chop the leaves up finer so more fits in the bag. Less trips to the compost pile.
Chris
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A53473)
2022 Gravely...
2021 FREIGHTLINER CASCADIA SLEEPER TRUCK (A54313)
2021 FREIGHTLINER...
2017 Ford F-150 Pickup Truck (A53422)
2017 Ford F-150...
VERMEER NAVIGATOR S3 D10X15111 DRILL (A51406)
VERMEER NAVIGATOR...
DESK (A53843)
DESK (A53843)
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
