LB400 Float Issue
/ LB400 Float Issue #1
kdierk
New Albany, IN
Kubota L2350
I am completely new to tractors and just purchased a used one. It is an Kubota L2350DT with an LB400 loader. The decal for the controls on the loader shows the float option pushed straight up. This would allow the whole lift arm to float. My unit actually floats when pushing to the right. And only the bucket tilt floats. The raise and lower stays in the same position.
Is this a correct setup? I have read several posts, and everyone talks about the lift floating while still maintaining control of the tilt. Which is exactly how the decal is displayed. However, mine is not like that.
Any assistance/guidance would be appreciated.
Thanks,
/ LB400 Float Issue #2
Reverse the curl and the lift hoses.
Push the lever fwd, to lower the lift, and push lever to the end and you will be in float.
Pull lever back, and lift arms raises .
Push lever to left and and bucket curls up.
Push lever to right for bucket curl down and more right you will be in regen/fast dump...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2012 John Deere 6170R (A57148)
2012 John Deere...
2020 ASV RT65 (A60462)
JOHN DEERE 850K WT CRAWLER DOZER (A62129)
JOHN DEERE 850K WT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Nissan Pathfinder SUV (A59231)
2018 Nissan...
