LB2204 Questions
   / LB2204 Questions #1
lfc
We recently purchased an LB2204, and are trying to figure out where to check the transmission/rear end/hydraulic oil levels (are they common?) We've been able to purchase service and parts manuals, but can't find an owner's manual.There are a few bolts/plugs on the side of the transmission housing, but by the looks of the tiny picture in the parts manual some of these may be retaining bolts so I'm scared to start removing bolts to see if they are level plugs. There are two fill plugs on the top of the trnasmission behind the shifter, but they both seem to go to the same sump.
If anyone knows where to check the oil or knows where we could get an owner's manual, it would be much appreciated.
Also, it has the add-on power steering kit. it needs new seals, but we were told by the Kioti dealer that the part numbers are NLA. Anyone know who made this kit - we heard they are US-made? Thanks!
   / LB2204 Questions #2
There is a bolt that you must remove on the left side of the transmission just above the clutch pedal. Or more precisely just above the foot rest about 1 inch above the very end where you toe would be on the foot rest is a bolt removable fill with fluid until hydraulic fluid comes out of this bolt hole.
   / LB2204 Questions #3
I will send a picture of this transmission fill hole but it'll be about a week.
2018 Gatormade 20+5 Gooseneck Trailer (A52748)
2018 Gatormade...
2017 SKY TRAK 6036 TELEHANDLER (A52576)
2017 SKY TRAK 6036...
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
2006 Ford Fusion SE Sedan (A51694)
2006 Ford Fusion...
2011 INTERNATIONAL MA035 ROUSTABOUT TRUCK (A52472)
2011 INTERNATIONAL...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
