Tires LB2204 Kioti r4 tire/wheels
   / LB2204 Kioti r4 tire/wheels #1
04geezer
Ashtabula
Kioti LB2204
Looking for complete matched set, front and rear, r4 tires and wheels for a '86 LB2204. I have the r1 ags on it now. I'm sure I can find a used set but don't know about offset, front to rear ratio ect.
   / LB2204 Kioti r4 tire/wheels #2
A full set for the following units will fit your LB2204-
LB2214, LB2614, LK2554, LK3054, LK3054XS, LK30, LK3504, CK series 25,27,30 and 35 (Not CK10's) and last but not least DS3510.
There are 2wd versions of the LB's and LK's listed above but they will only have R-4's on the rear typically and ribbed treads on the front.
The new CK10 series uses a slightly different bolt pattern in the rear.
Hope this helps.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2018 FREIGHTLINER...
2009 Champion C80 B Motor Grader (A50322)
2009 Champion C80...
2016 Dodge Ram 2500 (A50120)
2016 Dodge Ram...
Tires (A50322)
Tires (A50322)
2022 John Deere 6135E (A50120)
2022 John Deere...
