LB2204 3PH Speed Control Adjustment Grip broke
   / LB2204 3PH Speed Control Adjustment Grip broke #1
KiotiOwner
NW Hills, CT
Kioti LB2204
Could the Speed Control Adjustment grip assembly be replaced? I broke the grip off the control valve (assuming that is what it is). I have removed the 6 bolts which hold the plate on. Does the whole plate need to be replaced or can I get a replacement control valve? I guess I tighted the "grip excessively". Any assistance will be appreciated.
Jim
Wolverine Mini Skid Steer Auger Drive & Bit (A50514)
Wolverine Mini...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
Yale Electric Pallet Jack (A50514)
Yale Electric...
2016 Ford Explorer...
2011 Mack CHU613 T/A Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
