Lb1914 starting problem- suspect glow plugs
   / Lb1914 starting problem- suspect glow plugs #1
FishtheRainy
Baudette, Minnesota
Kioti Lb1914
I have owned this tractor for about 1 year; it is about 14 years old. It started fine last summer. This summer the only way I can get it started is by using starting fluid; if starting fluid is used it starts right up. It seems like the glow plugs are not working.
I removed what I think is the nut that holds the glow plug in place but got concerned that it might cause more problems and I want to use the tractor for mowing now since it starts now!
How do you replace them? Is it difficult?
   / Lb1914 starting problem- suspect glow plugs #2
On my 3054, it may be similar for you,
They are on the right side(as sitting on seat), there are three, they look similar to a spark plug, they have a solid wire connecting all three. Remove the nuts that hold the wires on then remove the glow plugs and install new ones. It wasn't to bad except that it was hard to get a socket on them. I had to grind the shoulder down on the socket because there wasn't much room between the motor and the plug. This should fix your starting problem.
   / Lb1914 starting problem- suspect glow plugs #3
its not to hard... just give me call if you have any questions... we stock the glow plugs
620-429-2602
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
2023 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2023 Ford F-150...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
Komatsu Pc200lc Excavator (A50514)
Komatsu Pc200lc...
Willmar 4300 Wrangler Loader (A52128)
Willmar 4300...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
