LB1914 Regulator burned up
   / LB1914 Regulator burned up #1
DeanKC
Hickory, LA
Kioti LB1914
After 17 years of ownership, my Kioti finally developed a problem. Here and elsewhere there have been comments and perhaps discussion regarding the regulator. For about a month the charge light would come on, then go off for no discernable reason. Put the charger to the 4 year old battery but it was 100% charged. A few days ago, smoke appeared so I shut down right where I was out in a field. A couple of hours later, I drove it to my workshop and arrived just as it began to smoke again.
It was the regulator mounted to the firewall. A vendor wanted about $150 for the part. On another site, a non-Kioti specific regulator was $40. I bought it because a TBN member from Australia adapted this successfully for his LB1914. The couplers are compatible, both 6-wire. The wire colors are different at 3 of the 6 connectors. The other half of the connector attached to the Kioti harness doesn't match either one.
I'm fit but pushing 80 so this wiring issue is a problem. I figured out how to attach the new part by making a mounting plate thus using the threaded holes in the firewall.
I have no problem with cutting the connectors and wiring with solder but since the two halves of the Kioti connectors don't match each other, color wise, perhaps I should fork over the extra hundred bucks.
If any members have dealt with this problem, I would appreciate the feedback.
   / LB1914 Regulator burned up #2
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2019 Dodge Journey Crossroad SUV (A50324)
2019 Dodge Journey...
2018 Chevrolet Malibu Sedan (A50324)
2018 Chevrolet...
TMA (A49461)
TMA (A49461)
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
