If you have a Kioti 1210 loader...
In the center cross tube of the loader on the driver side you will find a leg stored inside of the cross tube.
Remove the leg and pin it into the leg holder on the center of the cross tube it will be angled back towards the machine.
Slowely lower the loader until the bucket touches the ground.
Then there will be a 19 mm nut that will have to be taken off of each side where the loader sets on the mount (by each floor board) once the nuts are removed you let the plate swing down get back on the machine a curl the bucket back and you will see the loader lift off of the mount, make sure you raise it high enough to clear the front tires but not to high.
Shut the tractor off and take and move the loader joystick in a full circular motion to bleed of the pressure.. then unhook the 4 quick couplers lay them aside and then slowely back out.
