LB1914 Cracked Knuckle Arm
   / LB1914 Cracked Knuckle Arm #1
snagmaster62
I need some advice on the difficulty and any special tools necessary to replace a right side (looking forward from the drivers seat) knuckle arm. I am not sure how it cracked since the machine has not been worked that hard and I have addressed moving the stops to their correct positions based on posts regarding this recall item over a year or two ago. I have a shop manual but as pointed out in previous posts it is darn near worthless. Any technical advice on how difficult this replacement will be and if there are any special tools required will be very helpful since I can not decipher from the manual and will be getting myself into new territory.
   / LB1914 Cracked Knuckle Arm #2
It is a very easy job..... Bascily just your steering linkage and a couple bolts will get it off. If you need the parts we have them instock.
Jon, thank you for your reply, which helps me know that I will not be over my head as I tear her down. I will try to source the part locally if I can. Thanks again.
Toro Workman Utility Cart (A51694)
Toro Workman...
Toro ProCore 864 Series 64in Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
Year: 2020 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 190,820 Plate: Body Type: 2 (A51692)
Year: 2020 Make...
197711 (A51244)
197711 (A51244)
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
