Lawnmower on fire as I finished up mowing.
   / Lawnmower on fire as I finished up mowing. #1
jobguy
MN
Bobcat CT120
I shut down the self-propelled walk-behind mower and headed for the shed. Noticed a whiff of smoke from just above the muffler soon more smoke,,, more smoke and so on. I keep 3 fire extinguishers just inside my garage door,, by now flames about 4 inches tall. Put it out with a couple puffs from the fire extinguisher. The cause was dry dusty chaff/grass clippings.
Recommendations:
Blow old dry grass clippings out from under the cowling covering the engine once in awhile.
Keep fire extinguishers at a couple different locations around the place.
I had to run 200 feet to the nearest extinguisher.
Now I have an extinguisher on the tractor (fits perfectly in the round document holder that came with the tractor) just behind the tractor seat (Bobcat CT 120).
So now I have an Extinguisher in the House, Garage, Boat and the Tractor.
Thinking of getting more if I see a spot that needs one.
   / Lawnmower on fire as I finished up mowing. #2
Another reason... don't ask me how I know.
Some of the reformulated fuels are murder on rubber fuel system components.
My little Craftsman caught fire and was being fed from the fuel tank when the rubber supply line leaked.
Mentioned it to my mower shop friend and he said the new fuels have been great for business... lots of carb rebuilds and new equipment sold because of it here in California.
   / Lawnmower on fire as I finished up mowing. #3
Thanks for sharing your experience, there was a thread recently here about having a fire extinguisher on your tractor and the discussion also included having one in your home, car, outbuildings, etc. Whenever I am done with a push mower for the day I leave it outside and blow off any chaff before putting it indoors and let it cool down while outside. Maybe ten years ago I was running a front-drive self propelled push mower and it had such a clipping build up under the shield for the drive belt it was actually smoking from the belt frictioning the clippings. It is a PIB to clean the chaff out from the belt shield but I do it often now.
   / Lawnmower on fire as I finished up mowing. #4
Recommendations:
A lot of the floats don't shut off the fuel well either. A little plastic, inline fuel shutoff valve as close to the tank as possible is also a good idea. Shut off the fuel by turning the knob to kill the engine before putting it away.
   / Lawnmower on fire as I finished up mowing. #5
Its the ethanol in the fuel, it reeks havoc on the small engines, and gums ups your carb. You should really use a good gas treatment. We use this type:
It works great, and we had it highly recommended over Stabil, and a few others that I was using, after we had to have our snow blower, and chain saw carbs rebuilt.
The link:
Lubricants
   / Lawnmower on fire as I finished up mowing. #6
Good reminder for all of us.
I usually leave my push mower out of the shed to cool off for a while as a general practice. This thread is another reminder to keep doing just that, as well as the maintenance described.
Being in the People's Republic of California, UR may not have a choice, but for all my small motor stuff I buy premium as I can still get it without alcohol.
A smart, or even mediocre lawyer could pretty easily put together a class action suit, as there is a significant safety hazard directly created my our gubmints forcing the addition of alcohol to gasoline.
But, that would be holding gubmint accountable.
Only in a perfect world..... D.
   / Lawnmower on fire as I finished up mowing. #7
+1 on the Ethanol. Two weed wackers, Chain Saw,and push mower. All had to have new hoses and carbs cleaned. I am using an additive now and put up extinguishers everywhere. Also pointed them out to folks who are around here with any frequency.
   / Lawnmower on fire as I finished up mowing. #8
Thanks for posting. I use my hand blower to clean off my riding mower each and every time that I use it. It amazes me just how much grass clippings accumulate, especially when mowing early in the morning when dew is on the ground. I have an extinguisher on my riding mower, my tractor, one in each of my two sheds, two in my shop, and three in our home. Overkill? I don't regard these measures as being too cautious. Just attempting to be prepared as best as I can.
   / Lawnmower on fire as I finished up mowing. #9
One can also buy canned ethanol free gasoline from the major big box stores, at least some of them, or buy via mail order.
The canned gas is pretty expensive, but I keep a can around mostly for the shelf life since I don't use much gas. If I buy a gallon half of it is wasted each year (diesel on the other hand is another story altogether).
   / Lawnmower on fire as I finished up mowing. #10
I'm bad about cleaning off the deck on my 855. i've had it on fire twice while mowing in the 12 years I had it. I know they want you to leave the safety shields on the deck but they just pack full of dry grass.
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2015 FREIGHTLINER...
2013 FREIGHTLINER CORNADO (INOPERABLE) (A52472)
2013 FREIGHTLINER...
1273 (A50490)
1273 (A50490)
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
