bcarwell
I've been looking at drop and broadcast seed spreaders for my small pasture (3-4 acres). The ones I'm looking at are intended for lawns which explains the denser planting setting. But the lowest settings are 2 lbs. per 1000 FEET., yet the bermuda hay seed application rate is around 10-15 pounds per ACRE. Can you use these lawn spreaders for small acreage and if so how do you get the setting lower ? Do you cut it with sand or what ? The bigger ag (e.g. cone, etc.) broadcast spreaders (Tractor Supply, etc.) I'm told aren't really for tiny grass seed and waste too much. And they're also very expensive (~ $500+) compared to the "lawn" type (~ $200) I know with the lawn seeders I've got to do more passes which is fine (4 foot wide for the drop spreader and 12 feet for the broadcast spreader) and they also seem to provide more control for this expensive $$$ seed. But I'm worried about not being able to adjust them to lighter seeding. Any ideas ? What would you use for 4 acres ?
Bob
Bob
