lawn rolling
   / lawn rolling #1
deereman64
I have a JD 2210 and my property is flat. My problem is that this was new development and although the grass has taken well it is un even. I went onto the agrifab web site and they have a broad range of weights of lawn rollers upto 900 lbs. A couple of questions what do you think is the best weight to level out the bumps and when do you think is the best time to start rolling bearing in mind too wet would probably exacerbate the situation
   / lawn rolling #2
BEST WEIGHT?Ihave an old large propane tank,i stuck a shaft through,and filled with cement 400-500 lbs just about all my 11 hp craftsman can muster.
Best time? when i know i can do it without spinning myself stuck /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif When your gonna smooth things up,not tear things up,if you get what im trying to say
ALAN
   / lawn rolling #3
I don't think a lawn roller will help. You have voids in the yard that need filled in.
   / lawn rolling #4
I agree with Molerj, the roller will not level out the bumps, all it will do is compact the soil and weeds love compacted soil.
2016 Ford F-450 Ext. Cab 4x4 10FT Flatbed Truck (A51692)
2016 Ford F-450...
CROSSTECH 4200X 57" HYD BRUSH CUTTER (A51406)
CROSSTECH 4200X...
Dump bed (A51692)
Dump bed (A51692)
2005 CATERPILLAR 730 OFF ROAD WATER TRUCK (A51406)
2005 CATERPILLAR...
2003 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2003 FORD F350 XL...
