Lawn roller ideas
   / Lawn roller ideas #1
smoker
Bronze Member
Central NYS
Kubota B9200
I have a 4'x2' lawn roller that insists on leaking water. Suggestion was to use sand as weight. Have any of you folks used sand and did you fill it full, half full?? Grandson says it will hold ~20 50# bags of sand, I think I would need a
D-9 to pull it:) Appreciate any experiences you can share. Thanks, smoker
   / Lawn roller ideas #2
If you can't fix the leaks, You could fill it up 1/2 full and try it. Add if it pulls easily. Weigh a gallon of sand and see how it compares to a gallon of water.
   / Lawn roller ideas
I've welded on that thing for the last time! Made out of beer cans I think. I wondered if the sand would hang up and then fall or......? I'll bet there is someone here who has done it already. Water weighs ~ 8# per gallon and this is a 55 gallon roller so when its full there is ~ 400#. 10 50# bags would be about right. Just can't seem to see how the sand would follow the roller and stay on the bottom, or does it???
   / Lawn roller ideas #4
Sand should stop the leak.
But dry sand is about 100# per cu ft. If your rollers inside dimensions are indeed 2x4 on the money, you will need 1250# of sand. As opposed to about 750# of water. So it will be a little heavier, but I don't think you need a d9
   / Lawn roller ideas
Thanks LD1, just joking about the D-9. My question is how will the roller react being half full of sand? Like I said there has to be someone who has done this. Just don't want to go off half cocked. smoker
   / Lawn roller ideas #6
Lowes and home depot sell sand in 1000lb bags now also. It is cheaper than the 50lb bags. Sand needs to be pretty dry to flow like you want. Filling it completly full would help if it got wet and not wanting to flow.
   / Lawn roller ideas
"Wanting to flow", is exactly what I would like to know. Filling it full would really make it very heavy.
   / Lawn roller ideas #8
Calculate the volume of your roller. 24" x 48" should be around 12.56 cu ft. Water is 64.4 lbs per cu ft so that is 808 lbs plus the weight of the roller. Sand weighs 100 lbs per cu ft so that would be 1256 lbs plus the weight of the roller. Unless there is something you can add to sand to keep it fluid I suspect condensation in the roller will eventually cause the sand to pack and clump and result in jerky motion - especially when it sits between seasons.
I would simply fill it with sand. With the roller the more weight the better. I have one of the Ohio Steel 24" x 52" filled with water (920 bs) and I pull it around with my little John Deere 175 Hydro riding mower.
   / Lawn roller ideas
Looks like that will be the way I'll go. The condensation was my concern and the only way to get around that is to fill er up
   / Lawn roller ideas #10
Not sure how much concrete weighs per cubic foot but I have a roller someone gave me that was filled with concrete. Works good.
2011 19ft Avalon Pontoon Boat and Trailer (A44391)
2011 19ft Avalon...
2011 WESTERN STAR 4900 (A45046)
2011 WESTERN STAR...
16in Excavator Bucket (A44391)
16in Excavator...
PALLET OF SQUEEZE OFFS (A45333)
PALLET OF SQUEEZE...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A42744)
2021 Ford F-150...
Terms and Conditions (A42021)
Terms and...
