lawn mower
   / lawn mower #1
vaj
Lagrange, NY
JD 310d, JD 4110
Alright, I have a choice between a new 4110 with 60" mmm for 15700 at a Dealer and a used 4210 with 7iron 60" mmm for 14500 from a new holland dealer. The "used" 4210 is an ehydro with only 14 hrs. I only have a couple sloped acres to mow and will use it also for the 1000 ft driveway to plow and grade item 4 occasionally. The lawn is all wide open, no need for a tight turn radius. I never even looked at a tractor this big, and was even considering the 2305, however this deal I feel may be too good to pass up. Any input on just how overkill the 4210 will be for my needs.
Also, will add a loader once I sell my 310d backhoe so I am not scared otherwise of the bigger machine.
Appreciate it.
EDIT - As I research, I read some old posts about a 200x model loader for a 2210 which is not removable while the cx version is. As per the deere website, the 300cx is not available for the 4210, only the 300x. Does anyone know if the same rules apply for this model, meaning the loader I will eventually buy will be for the most part stuck on?
   / lawn mower #2
If I had the same choice. The 4210 would be in the barn.
Although I think the 60" mower is small for the 4210.
   / lawn mower #4
That's too much money for the 4110 with deck. Given the choice, I would take the 4210 and yes, like JDFANATIC said it's a quick verison for that unit. Be aware, the 4210 does not have a front blade quick hitch option, so if that a concern you might look elsewhere.
   / lawn mower #5
I Agree That $15,700 For The 4110 W/60" Deck Is Steep.Myself,I Would Go For The Used 4210.
   / lawn mower #6
Well, the MSRP for the 4110 is $16,000, I don't know what the mm should go for, but that may not be all that high. And he gets the new guaranty, where as used he probably don't, right?
   / lawn mower #7
My dealer has a new 4110 with loader for 13,650 for comparison. I wanted a little bigger so I am looking at the 2520. JC
   / lawn mower #8
I bought my 4310 with 430 loader for $16,800 out the door with 0% financing for 3 years in November 2003. Mine is shuttle shift, not HST so that brings the price down a little.
   / lawn mower #9
Good Point On The Warranty.I Do Know Deere Also Has
$800.00 Off The 4110 Right Now To Help Move Them Since
They Are Being replaced By The 2320.
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
1993 Barrett Gooseneck Livestock Trailer (A50514)
1993 Barrett...
80in HD Tooth Bucket with Side Cutters (A52128)
80in HD Tooth...
71067 (A49346)
71067 (A49346)
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
