Lawn mower vs tractor
   / Lawn mower vs tractor #1
CrimsonTide
Alabama
I just purchased a new home in Alabama after spending 10 years in Nebraska post Air Force. I have 7 acres mostly flat and few tress and obstacles. I am not sure how smooth the terrain is because it has not been cut all season.
I don't have a need for a tractor currently, but do need to mow the grass.
I have a local dealer end of year selling a ZTR Cub Cadet z-Force 60 60" cut 23HP for $3500, new with warranty.
I am having trouble deciding if I should get a lawn mower or a used tractor with a belly mower, maybe even a bush hog to keep up the property.
Thanks in advance.
   / Lawn mower vs tractor #2
If the land not to rough you might consider gang mower setup w/good second hand tractor,if your planning to mowe let's say every other week and have the time I would look for comfortable seat w/leg room ZTR may offer this setup.
   / Lawn mower vs tractor #3
For 3500.00 you're not going to touch a reliable tractor/mower set-up. If you need to mow, go with a lawnmower whether it be a zero turn or a lawn/garden tractor. If you have tractor sized tasks, pony up and spend 4x that for a tractor. IMHO.
   / Lawn mower vs tractor #4
I have the 3 below listed tractors to maintain my place and I only have 2.33 acres.
I'd shure hate to try it with a low end entry level machine like you mention on my properly.
I don't even want to think about tackling 7 acres that way.
   / Lawn mower vs tractor #5
I purchased a Lazer Z 60" for just that size lawn few months ago. (30+ hours at this point) I have other mowers but it took too much time with them. Have a dealer drop one off for a try, I think it will be a real eye opener.
Best of luck!
   / Lawn mower vs tractor #6
What do you want to do? Do you want to mow all 7 acres regularly? If you do, you really should spend more than $3500 on either a tractor or ZTR mower. You should have at least a 60" cut, and you will be putting 3-5 hours on the machine every time you mow. IMHO, that demands a premium LG tractor, a subcompact, or a commercial ZTR.
Do you want to do other tasks besides mow? Then you need to consider a tractor, whether it would be a garden tractor, sub compact or compact.
Do you want to mow 1 or 2 acres regularly? Then, a cheaper lawn mower will do the job, and you could consider a used comapct or farm tractor with a bush hog for the rest of the acreage.
Hope this helps. It's always easy to spend someone elses money.
Will
   / Lawn mower vs tractor #7
That is a beautiful place!
The terrain issue on a new place that I was unfamiliar with would make me lean toward paying someone to mow it for me the first time. That way you could watch the operation to see if there were any problems, and it would also help you answer your question.
If you are planning to keep the entire 7 acres mowed regularly, as some others have said, a compact tractor from a local tractor dealer with the 3 point hitch 60" mower and turf tires. It will last many years.
Thanks for the responses.
At this point I don't know what I would do with a tractor on the land other than mow. A tractor seems like a lot of money to me to just cut grass. My friend just bought a place 7+ acres mostly wooded and got a kubota said he loves it, but I can't for the life of me think what else I would use it for. Now on the flip side a mower is a high maintenance deice of equipment. Having never owned a tractor I don't know if that is the case.
The Z-Force 60 is a commercial grade mower with higher gauge deck and frame than residential models. Also bigger hydro pump than residential models.
I had 5 acres previously, 3 to mower and used a push mower, a POS riding mower and wheel barrow+shovel(s) to do whatever needed doing.
I would anticipate mowing around 6 acres bi-weekly. And the areas around the house weekly. As we landscape, put in trees, out buildings etc, the mowing area would be slowly reduced.
   / Lawn mower vs tractor #9
Welcome to the group, and thank you for your service.
John Deere used to publish a little book that had a table in the back that would tell you how many acres per hour you could work with an implement of a given width at a given speed. There comes a point where you can't go any faster or use a wider implement because of terrain, but that little table really helps put things in perspective.
Tractors may be more expensive initially, but how many lawnmowers are still in daily use at 30 years plus old? What's the resale value of a lawnmower versus a tractor? With the way prices are headed, I would consider a good tractor a good investment.
Fuel economy is also becoming more of an issue. My diesel tractor does more work per dollar spent than my lawnmower, but it's not the right tool to cut my lawn. Diesel engines are also built to be stronger than equivalent gas engines and far outlast gas engines.
I think a lot of us end up with a variety of machines either because we like them or because they serve special needs. You can't beat a ZTR to cut a large lawn with obstacles, but you can't beat a small tractor for bushhogging, grading the drive, etc. If you take your time and shop around carefully in the used market, you're money will go further than if you plunk down all your cash at the local tractor dealer for one new machine.
   / Lawn mower vs tractor #10
This is what I am doing. We just bought 7 acres and I can tell from walking around it that it is rough, probably from the initial clearing years ago. I'm having it bushhoged this week and then will be able to get a better view of what needs to be done. If too rough for a Zero Turn then don't know whether to spend the money on dirt and rent a tractor to smooth it out then buy a Zero Turn( which I could also use at my current place) or just buy the tractor. No home on the site yet and hauling is also an issue.
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
2008 Chevrolet Impala Sedan (A51694)
2008 Chevrolet...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
2022 John Deere 410R Sprayer (A53342)
2022 John Deere...
Ingersoll Rand Air Compressor (A51573)
Ingersoll Rand Air...
