Lawn Irrigation
   / Lawn Irrigation #1
thcri
Elite Member
Minnesota SE
New Holland TC29D, 2001
Does anyone know of an attacment you can put on your 3 point to install or trench for lawn irrigation?
murph
   / Lawn Irrigation #2
They make 3 point trenchers
I'm sure you could rent one
Honestly, it's pretty cheap to rent a trencher.
What are you trying to do?
I did lawn sprinklers for YEARS.
I'm a guru. :cool:
   / Lawn Irrigation #3
murph
I have a 21-hp Kubota B7510HST and a King Kutter middle buster/subsoiler combo ($139 at Tractor Supply Co) that I'm using to dig 12" deep trenches for PVC irrigation pipe in my landscaped areas.
The 2" wide chisel point that comes with the subsoiler is a little too narrow. I prefer a wider trench so I can use my 4" wide trench shovel to clean out the trench. So I bought a $5.00 6"-wide chisel plow sweep from Agri-Supply. The sweep bolts easily onto the subsoiler frame and cuts a nice trench in the soil. The soil is soft due to about 2 months of rain, so the 7510 has no problem pulling this sweep a 12" deep into the ground.
I'm installing 1" dia rigid PVC pipe that has tees included for the sprinkler risers. So I can't use the subsoiler trick that a lot of folks on TBN have employed to drag long pieces of flexible irrigation pipe directly into the trench in one operation.
   / Lawn Irrigation
I'm a guru. :cool:
Renting things around here for subcompacts doesn't much exist. I want to sprinkle my lawn. I am sick of dragging hoses around. I want to start out by doing my front lawn and part of the back lawn but I have over an acre to sprinkle plus I want to run a fairly large line down to my garden.
murph
   / Lawn Irrigation #5
murph
yeah, a 120 dollar middlebuster from tractor supply, ADJUSTED CORRECTLY for entry angle, I get trenches 8 to 12 inches with on epass, couple of passes gets deeper.
   / Lawn Irrigation #6
murph
I did that two summers ago. Get your plan together, then rent a walk behind trencher. I planned on two days for about 3/4 of an acre. Picked up the trencher at 7am and was done by 1:30. And that is in soil that is more rock than soil. In MN, you won't have any problems at all. Just have a drawing done to scale, so that you know what you're doing and where. I think my one day trencher rental was around $150. Yes, I might have been able to buy a middle buster for that or not much more, but then I would have had to clean the trench out with a shovel, and I had close to half a mile of trench. The Vermeer I rented dug a perfectly square trench and laid the spoils just at the edge for easy backfilling.
I'm probably going to do the back yard this Spring. Another 1/2 acre, but filled with trees to work around. I might go pulled pipe for this one.
   / Lawn Irrigation #7
murph
You miss what I'm saying
you can rent a real trencher for not much money, not just an implement
Lots of home owners want to put in sprinkler systems
   / Lawn Irrigation #9
murph
Murph, what do you plan to use for heads? Impacts or rotor? Just be sure to size the pipe correctly. Go to Hunter or Rainbird for the friction/loss tables. Do you irrigate with domestic? Raw water such as ditch water? Impacts handle dirty water much better then rotors or gear driven but gear driven have super coverage and typically less overspray. Lots of little things to think about that can make it work well and last years or leave a lot to be desired. Out here, we irrigate from May to November.
   / Lawn Irrigation #10
Since this has kinda turned into a irrigation thread.
use real wire for your valves, 80% of expensive irrigation problems are electrical. Direct Bury 14ga real wire. Yes, it's ungodly expensive esp. lately, it's worth every penny.
Use 3M DBY and DBR connectors, (direct burial) again, I've pulled up 20 year old connections that are crystal clear.
Best:
spray heads: Rainbird 1800 series, by far, MPR nozzles
Impacts: Rainbirds, but loud, nobody uses these anymore
Rotors: Hunter I20's, the next step up from the PGP's, cost about $7 more a head, the coverage is fantastic and light years beyond the PGP, also has a 5 year warranty.
Valves: Rainbird.
yes, this is all commercial grade stuff. it's expensive when I have to come fix it in 5 years and it will never work as well as being done right the first time. Put it in right and be done with it. The price of a sprinkler system is 80% labor, who wants to dig that all up again.
Space it all correctly Too close is better than too far.
Trench everything, do not pull pipe, always leads to bent ends. Also, I tend to bury deep, 18 to 24 inches, 24 to 36 inches for mainline. It never gets hit, mucked with, changed, etc. (i've actually aerated thru pipe put down too shallow, that's like 2 inches)
If using poly, use screw clamps only, crimp ons SUCK.
If using PVC, use primer and do a good clean joint and then use Gray glue, it dries slower so you get a better joint. (esp when it's hot out)
Febco backflows are the best, much easier to work on. use a female copper joint to mate to the PVC mainline (copper female to PVC male)
HTH
2018 CATERPILLAR 320GC EXCAVATOR (A51242)
2018 CATERPILLAR...
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
2011 Chevrolet Cruze Sedan (A50324)
2011 Chevrolet...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
2025 REDEDLIFT CPD25-XD4 FORKLIFT (A51222)
2025 REDEDLIFT...
