gsganzer
Elite Member
- Joined
- Jun 11, 2003
- Messages
- 3,066
- Location
- Denton, TX
- Tractor
- L3800 w/FEL and BH77, BX 2200 w/FEL and MMM
This is kind of a follow up to another thread that talked about "what kind of sprayer to buy".
I thought I'd follow up with my experience. I've usually brushed (trim work, siding) or rolled (walls, ceiling) latex paint. However, I had 8 raised panel interior doors that required painting and I knew that a brush was going to be time extensive and probably wouldn't give me the results I was after.
I have an Ingersoll HVLP sprayer with a 1.5mm nozzle that I use around the shop for spraying enamels, laquers etc. After talking to the help at the Sherwin Williams store, I decided to give it a try.
The key to spraying latex is to use a product called "Floetrol". It's a latex paint conditioner sold at paint stores, Lowes, Home Depot etc. In a quart container, I'd put in 20 oz. of Sherwin Williams "Duration" paint and 10 oz. of Floetrol. The benefit of the floetrol is not only for thinning but for leveling. It worked real well for the application. I had the gun adjusted to spray fairly heavy and you have to move slowly to allow the sprayed surface to become "wet". It looked a little orange peel at first, but leveled fairly well. I was using a satin finish on a rough surface so I had a lot of forgiveness. You want to paint out of direct sunlight, so the drying process is slowed and the paint has a chance to level. I sprayed the doors with two coats. One coat would have probably been sufficient, but with the satin paints I've found that two coats is needed to get the satin look.
It worked fine for painting doors, trim etc. This setup wouldn't work for painting walls, siding etc. It just doesn't throw out enough paint. It sure saved me a whole lot of time and saved me the price of a new sprayer.
