Largest most offsetting tiller?
   / Largest most offsetting tiller? #1
PsRumors
Cartersville (NW) Georgia
Kubota L45
My brother's erosion control company has been asked to till 100 acres around solar panels. He needs to offset under the panel and back towards the support mast. He will by a tractor if necessary but has tractors ranging from 40hp to 225hp.
So what is the most offsetting tiller available? Is there one that will offset 60" from center line?
Thanks in advance for any help.
   / Largest most offsetting tiller? #2
There is a company - Brown Manufacturing, Ozark, AL - that manufactures HD offset disk plows. I can not tell by their specs how much offset their equipment has. It could be worth your time to give them a call - 800-633-8909. Good luck.
   / Largest most offsetting tiller? #3
There are lots of tillers that offset but most won't move over that far. You could do a custom set up I suppose with a chain drive to offset the driveline or you might find a small tiller on a garden tractor will fit under the panels with out clearance issues. I would think the scale of the job would be a factor, how much close quarters work he will have.
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
CASE 621G (A53843)
CASE 621G (A53843)
2013 Honda CR-Z EX Hatchback (A53424)
2013 Honda CR-Z EX...
2021 Ford Explorer SUV (A51694)
2021 Ford Explorer...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
