Chipper Large wood chipper
   / Large wood chipper #1
GreatWhitehunter
Veteran Member
Eastern CT
JD 110 TLB
I know it's not really a tractor thread but I think fellow TBNer's will have the answers I seek. I recently rented a 12" cap vermeer wood chipper. I was amazed at the versatilaty of this machine. I was thinking on getting a pto chipper but after the trailer model I wouldn't consider the later. Does anyone here own one of these units? I know there $$$ when new,but I was thinking of buying a used Vermeer unit. It's around 5k and I plan on building a new home in the very near future. I think the chipper would be a good toy, I mean tool to have around. I was able to send entire tree tops through this machine and end up with useable chips instead. My question is where to buy and what to look for. I was planning on renting it to a few friends also. Should I inquire about insurance? And info on this purchase would be greatly appreciated. Also what brands are better than others? I really liked the Vermeer but the Morebarks look rugged also.
Matt T.:D
   / Large wood chipper #3
I'd suspect that $5k won't buy you much other than
a used 6" capacity. We have a Gravely 7" trailer mount
(Kohler 25hp) which is probably similiar to what a 30 hp PTO can do.
Paid $9k in 1998 for it. Almost all in this 6" class are
disk chippers. Depending on the wood, the chips may
be usable but with dry oak which is what we run through
mostly, the chips are really almost dust (still useable for
edging, etc)
A 12" vermeer could likely be a drum chipper which will produce
much better chips. Check the used machinery trader
sites. If you had one lined up at the $5k price I'd say you couldn't
go wrong. I did a quick check and didn't see anything under 16.5k
or 1000 hours.
We don't rent out anything we own due to liability. Of course
your milage may vary but our homeowners covers it on our
property and our insurance company was _very_ concerned
about the chipper vs. other machinery. Basically, we left it
that if there was ever a liability claim off the property, it had
to be operated by myself for no fee. Insurance Co's underwriters
pondered this for _two weeks_
There are a bunch of good ones based on where you're at. Vermeer/Morbark/Bandit. As always, parts and service are
the key. When I was shopping I didn't see too many differences
between the brands. Dual wheel hydraulic feeds and a big engine are
what you're looking for.
Having your own vs. renting is certainly nice. We mostly run branches
up to 4" through it. Found that anything larger than that goes
for firewood.
Hope this helps.
Mark
   / Large wood chipper #5
I bought an ancient 16" drum type powered by a Ford 330 V8 back in 2002.
Very fast feeds about 100' per minute (10x) the hydraulic feed rate.
It eats whole trees - anything I can lift into it's tray, no trimming as it busts the branches on the way in.
Never was overly concerned with safety until one Spring I fed a 30' pine overwinter blowdown into it, turned around to go back & lift the top & it was gone - devoured by the machine.
That caused my to look on forestry & arborist forums for advise & found out this thing is lethal. It is the one thing I do not borrow out.
Do some research & treat it with extreme respect.
I paid about $800 for mine, had to rewire the gauge panel before it worked.
   / Large wood chipper #6
Ditto Barry. I have a ~1960 Fitchberg "chuck-n-duck" w/ an I-6 Ford, maybe 8" capacity, probably 6". Got it in xlnt running condition for $2500. Bought it from an arborist, and machinist, it throws 0.030" thick chips, solid oak, by design. No need for power feed. It's the only machine I have that I'm afraid of. No one borrows it :)
   / Large wood chipper #7
My brother is supposedly inquiring about a vermeer chuck and duck w/ a ford v8... thinks i can get it for about $1000 off his friend... these are scary beasts! if i can get it, i may weld a rebar grid to the opening such that my arms can't reach the drum (if that's possible, not sure on the length of it) but i think i'd have to fabricate something...
   / Large wood chipper #8
Input tray is about 3' long from lip to drum knives on mine.
Not sure about rebar, accident happens by arm or leg snagged by tree & pulled in, shoulder bones may stop, but leg is large enough you get pulled all the way in. Clearing a jam is particularly dangerous.
Hydraulic feed has e-stops & power reverse bars around input.
No gloves, no loose clothing, no distractions when feeding. Massive flywheel/drum assy spins the engine for several minutes after shutoff.
   / Large wood chipper #9
We shared a Vermeer 6" - 20 hp trailer model chipper for several years with a friend. Since everything above 3 inches is firewood for us, it worked fine. The chips were more like grindings, not suitable for landscaping. Since we are in "hill" country on the west central edge of Wisconsin, we decided on a 3 point mounted 6 inch Valby chipper with hyraulic feed. I did not like trailing the Vermeer chipper around our terrain. The Valby gives nice sized chips for paths and garden areas. Good equipment is never inexpensive, but given consistent maintenance it will last and have good resale value. Good luck.
The Vermeer used site is where I was looking. I also looked on ebay. There's a tree co near me thats always selling items,I may try them. I have no fireplace so I want to chip as much as possible. I know that will change when I build so I suppose a smaller capacity would work. I rented a Vermeer bc 1000 it had hydralic feed and safety up the ying tang. I learned to clear the feed fast after the trees in the rollers. I can see getting hung up quite easily. I noticed the large cap models are all in the 100hp + range so I think that's the direction I'll head. What type of routine maintence is needed for these units?
Matt T.:D
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
30007 (A53424)
30007 (A53424)
2021 CASE IH Steiger 540 AFS Connect QuadTrac Tractor (A53485)
2021 CASE IH...
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
CHAMPION AIR COMPRESSOR (A55745)
CHAMPION AIR...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A54814)
2012 Freightliner...
