timb
Veteran Member
- Joined
- Jun 14, 2002
- Messages
- 1,058
- Location
- Southwest PA
- Tractor
- Deere 4710/reverser, JD 318 (still needs TLC), JD LT160
According to the spec sheet, my 4710 takes a BCI Group 27F battery (12-1/2L x 6-13/16W x 8-15/16H) with a minimum 0 degree (F) 650 CCA.
Optima does not make an exact group 27F model, but it looks like any of the red tops, and all of the yellow and blue tops except maybe the D31 series will fit, and all but the D51 yellow tops have at least the minimum CCA power.
I've read the blurbs on the Optima site 213 times but I still can't lock down whether a yellow top is acceptable for long-term use as a starter battery. The red top in my Jeep has been a champ - especially in the winter.
So - has anyone put an Optima into a large-frame JD? What did you use?
