BruceWard
Platinum Member
I was at a scrap yard looking for a piece of 4x6x3/8 angle to strengthen the back of my bucket and lucked into a CAT branded cutting edge that is 5' long, 10" high and 1/2 or 5/8 thick for $20.
The 4x6x3/8 angle is mounted to the back of the bucket and has three 5/8" nuts welded to the inside to allow the cutting edge or chain hooks to be attached.
On Friday I was smoothing out a pot holed church driveway and parking lot. I used the bucket to move around some material to fill the holes. Then drove over that material to compact it. After working for a while with the bucket I bolted on the cutting edge. I use it in reverse with the bucket floated. It worked well. A ~ 30,000 pound tracked loader has been working in the area and left unevenly packed ground. I got the parking lot pretty smooth with the diesel I had but packed up before I ran the tank dry. I am going back next week and plan to try the cutting edge with a full bucket for additional weight.
Here are a few pictures of the cutting edge attached.
Perhaps this is not as good as a box blade but it goes on quickly with 3 bolts and takes up a lot less room on the trailer.
