Large culvert on Ebay
   / Large culvert on Ebay #2
you aint hauling that home in your pickup
   / Large culvert on Ebay #3
It is worth more than 20 bucks for scrap metal.
   / Large culvert on Ebay #4
Things ppl will sell.. BUT if you needed one that would be a great price, especially if transportation wasnt a problem..
Wonder if Texas DOT is missing any surplus stuff? LOL
Brian
   / Large culvert on Ebay #5
I actually almost bought a 12' X 25' culvert earlier this year. The problem was that, the day before I was going to buy it, I called and found that the clearance for most bridges and utility lines is 13'6. The deck of my trailer is 30" tall. Add that to the 12' tall culvert and I figure I wouldn't have made it home! :eek:
Unless you have a use for them, the culverts are pretty well worthless. The metal is heavily coated and most scrap companies won't even take them; let alone pay you for them. Most I've seen lately have been coated not only with a rust preventative, but also coated with a thick black, tar like, coating. The one I was going to buy had an "anti-fungal" and "anti-bacterial" agent in that black coating. It was supposed to prevent algae and stuff from growing to it. I have no clue if it works or not.
I have the unpleasant task of replacing a 10' culvert under my driveway sometime in the next ten years or so. It was not coated in any way, but is 3/8" thick steel. My guess is that it's 40 to 50 years old now. I doubt it's still 3/8 thick everywhere now. I can't decide whether to spend the big bucks and build a bridge, put in concrete box culverts, or put in a new coated (and permanent - for my life) culvert. I need to span about 20 feet wide and 10 feet in depth. Right now my 10' culvert is a sort of bottle neck in the creek. However, only twice in 20 years has the creek gone over the culvert. And then it went through the two 'emergency' overflow side culverts I put in to relieve pressure if the creek ever was to get that high. Now, what to do...? :confused: The longer I wait, the higher steel prices get.
WOW Dargo, that must be scary to see your 10 foot culvert full of water and overflowing!!!! Did you get any pictures?
I'm always looking on ebay and the local classifieds for culverts and things I can use. One time I found a 24 inch culvert, 40 feet long that I was able to get for $300 delivered. I found my 5ft disk in the local classifeids for $295 in perfect condition and now I'm always on the lookout for another great deal.
Eddie
   / Large culvert on Ebay #7
1) concreet box culvert Crest Precast Concrete Box Culverts (a couple of 10x10 next to each other would be about right) ;)
a 10x10' box culvert is 21% larger than a 10' round culvert
2) bridge.
   / Large culvert on Ebay #8
Thanks for the link. That honestly looks like a much easier way to cross the creek rather than a bridge. However, I'm afraid that with two side by side, I'd collect limbs and other trash on the center part. I know that each section would be more than the one I currently have though. Maybe the center wouldn't be a problem? I sure like the ease, strength and long term solution though!
   / Large culvert on Ebay #9
its common to set 2 next to each other... yes you might get some debris build up, but hey, wait till dry season and harvest it. :D
With a creek that size id strongly recomend haveing a profeshional <cough> engineer <cough> look at your water shed area and size the culvert right.
then your not building something overly big, or go to all the expense of putting something in when you wind up with the same problems as before (with overtopping etc)
2014 Top Hat Industries 18FT T/A Utility Trailer (A52377)
2014 Top Hat...
2844 (A54757)
2844 (A54757)
2021 TAKEUCHI TB240 EXCAVATOR (A52705)
2021 TAKEUCHI...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A55218)
2016 Ford F550 4x4...
2016 Hyundai Tucson (A53424)
2016 Hyundai...
2005 Dodge Caravan Van (A54815)
2005 Dodge Caravan...
