Landscape Rake XB 60 nice rake but.
   / Landscape Rake XB 60 nice rake but. #1
Imold
Platinum Member
West Central Mn.
MF GC1705, Cub Cadet RZTL, Husqvarna Rider.
I bought a XB 60 King Kutter landscaped Rake and it did not fit my country time quick hitch, it was to narrow so I took off the QH and mounted it the standard way and went out to try it out a bit, it will definitely be a asset to my other 3 point accessories but now I need to go back to the city and buy 2 lower arm pins, looks like the 6.25 or the 6.50 pins will work to get the bushings far enough out to hook onto the QH, I am sure if I would of got the 72 inch rake it would of fit fine being I ran into the same issue with the 48 inch box blade.
It is one of those aw crap moments when you know you will probably need to buy something extra to make a item work but you forget to do it, I went and bought the bushings looked at the pins and walk off without the pins knowing that I would probably need them now I get to spend 2 hours driving to get something I should of bought to start with.
This is not the first time this has happened and it probably will not be the last.
Jim.
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2013 Ford F-650 Flatbed Truck (A51692)
2013 Ford F-650...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A52748)
Koyker Loader...
Informational Lot - Financing (A52748)
Informational Lot...
