Landscape Rake Vs Box Blade!
   / Landscape Rake Vs Box Blade! #1
Mahendra420
Valdosta,Ga
Mahindra 2810
Which is better?Should I buy a rake or a Boxblade?
   / Landscape Rake Vs Box Blade! #2
Check out the similar threads at the bottom of this page.
   / Landscape Rake Vs Box Blade! #4
What is it that you want to be able to do? 2 completely different animals you are talking about.
   / Landscape Rake Vs Box Blade! #5
What do you need done?
Kind of like asking: "Do I need a rake or a hoe for gardening?" :)
Bruce
So I needed both.I need a backhoes what I need with a thumb.
   / Landscape Rake Vs Box Blade! #7
You could compare a box blade and a straight rear blade but not a landscape rake. The rake is just that, it rakes a bit of material from side to side but it wont dig into the ground very much or move dirt as it is just designed for the dirt to flow between the teeth of the rake.
If you need a box blade, I would look out for used. There are tons of them setting around unused and in very good to almost new condition at likely half of the new price.
   / Landscape Rake Vs Box Blade! #8
You missed the other point. Powered rake or not?
A powered rake is like comparing a hand (carpenters) plane to an electric one.
A lot of it gets down to how much money you can or want to spend, and what conditions are like in your particular environment.
   / Landscape Rake Vs Box Blade! #9
A landscaping rake can level soil as can a box blade. If that is the goal, my preference would be the box blade. But we need more info on what you need to give you good advice.
   / Landscape Rake Vs Box Blade! #10
You can also purchase rake w/drop down blade.
2023 FORD F-250 SUPER DUTY (A52472)
2023 FORD F-250...
2015 Dodge Challenger Coupe (A50324)
2015 Dodge...
Tradewinds Power Unit (A50120)
Tradewinds Power...
2014 PETERBILT 367 (A52472)
2014 PETERBILT 367...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A52748)
GOODYEAR SET OF...
(2) Galaxy 180/95-14 (2) 11.2-24 Tires and Rims (A50120)
(2) Galaxy...
