Landscape Rake size for B2620
/ Landscape Rake size for B2620 #1
628pm
Centralia, Illinois
kubota f2690, 2020 Kubota BX23S, JD Gator 2018 XUV835M HVAC
What would be a good size landscape rake for a B2620? Will be removing branches and debris from a couple of areas where we have bulldozed.
Thanks for the help in advance.
Bill
/ Landscape Rake size for B2620 #2
Bill
Your signature states you run a 60in MMM/RFM/blade so in keeping a 72in landsscape rake would be a good fit.
/ Landscape Rake size for B2620 #3
A 6' will be perfect for your tractor. I have a 5' Woods, my 2620 does not even slow down when itsloaded with gravel. I have borrowed my brother's 7' Landpride, and with heavy use, my tractor struggles a bit.
Will
/ Landscape Rake size for B2620 #4
yes a 72" will be a perfect match. :thumbsup:
/ Landscape Rake size for B2620 #5
I use a 6 foot rake on my 2920, no problem. Had a 7 foot blade from a older tractor that I just used to grade a gravel driveway and it pulled fine.
Thanks all. I plan on purchasing 6 ft rake this weekend.
Bill
/ Landscape Rake size for B2620 #7
6' is what I use on mine also. I also used it on my old B7200 with no FEL and it worked fine. With the extra weight of the FEL on my 2620 no problem at all. I use mine for similar purposes. I use it to clean up an area when I dig up a stump or when I reclaim the woods to be yard. I bush hog and then go in with the rake to rake up all the debris. I got mine from a place called Rural King for around $250 and it seems to be holding up very well. No broken tines yet.
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A61307)
2023 Kubota...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
2003 Land Rover Discovery 4WD SUV (A59231)
2003 Land Rover...
DEUTZ MARATHON...
2019 Caterpillar 259D (A60462)
2019 Caterpillar...
