landscape rake length?
/ landscape rake length? #1
InlineDieselFan
Adna, WA
kubota
I have been thinking and I know that is dangerous.
I have land that was logged about 7-10 years ago and they left lots of branches and some small logs up to 12". We recently got a box blade so that we could level the yard area aroound the house, then as an after thought I decided I could use the rippers with the top-link tightened up to free the logs and branches from the dirt. So far it has worked good in my experiment area, I know lots of the big stuff will haveto be moved by hand or the bucket.
Finally to the rake length, do I go with a six footer and pull it straight behind me, 90 degrees to the tractor? Or my thought is to by the eight footer and place it at an angle, its overall width would still be smaller than my tractor. Then a lot of the small pieces of wood could be shoved/pulled to one side. Kind of like when you used a push lawn mower back in the old days.
thanks steve
thanks steve
/ landscape rake length? #3
I wonder if a tooth bar on your bucket might be better. Tip the bucket so the teeth are strait up and down and use it like a rake. When I use my rake fore cleaning up around my brush pile it seem half the branches get stuck between the tines then you have to stop and clean out the rake.
/ landscape rake length? #4
2015 Kenworth T680 (A64127)
2015 Kenworth T680...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63688)
2023 New Holland...
2022 Mercury Verdado 300HP Outboard Boat Motor (A61574)
2022 Mercury...
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
378909 (A61166)
378909 (A61166)
