Landscape rake for BX, XB or standard
/ Landscape rake for BX, XB or standard #1
redharley
central, Pa
BX2230
Hey guy's thinking of make a purchased of a landscape rake for my BX2250.Since I've been unable to find a used one in my local area,I was thinking King cutter would serve my needs.Basicly home use I have about 700ft of gravel driveway of my own,plus I am sure a neighbor or two could use a hand.Also 6 acre's of field,5 acre's woods,2 acres lawn. My question is this would you go with the XB series or the standard series.Pricing is about the same for 5ft xb and the 6ft standard at my local TSC, gage wheels are extra for both or I could make a set.If I could get away with a 7ft standard there is one on clearance for $383.Lift clearance a problem for anyone?Any thought's would be helpful. Thanks in advance
/ Landscape rake for BX, XB or standard #2
/ Landscape rake for BX, XB or standard #3
Have both the XB Box blade and Angle blade for the BX2230 with turf tires and they are a good match for the lift and pulling power of tractor. The 2250 has a little better height on the 3 point and may be able to use the regular blades. I also have a 7 foot angle KK blade for the L3130 and Massey MF35 and in no way would i try to put that on the BX, it takes too much powr to pull it and the BX could not lift it high enough or coiuld you pivot the blade around enough to effectively use it.
David
Thanks for the input guy's,that is what I was hoping for if anybody has tried something your interested in just ask on this site.I'll check out the link.Any other thought's out their?
/ Landscape rake for BX, XB or standard #5
I had a standard cat I seven foot landscape rake that I could move with my BX but it was difficult to hookup... lift arms didn't work well... two narrow. I would just move it... I'm sure you could not really do any work with it.
mark
/ Landscape rake for BX, XB or standard #6
I've have the 5 foot XB from tractor supply for 3 years, works great on my driveway. Good product and right weight for your tractor. I've got a BX22.
I've also done lots of clearing and rock removal for seeding grass and couldn't imagine the work it's saved. Easy to level if you eyeball it to the back of the tractor below the lights. Keep it tight so it don't swing around and have at it.:D
/ Landscape rake for BX, XB or standard #7
I had a standard profile rake for my 2200, and it had lift issues. I bought a Woods Estate Series (sized like a XB) rake 3 years ago, and it is much easier to use. I found the Woods to be a better constructed rake. I paid $650 with the gauge wheels.
Will
/ Landscape rake for BX, XB or standard #8
I am using a six foot King Kutter Box Blade and Rake. They do a wonderful job and are well built but I Have an L-2800. Sure glad I went to the six foot because it gives me about six inches extended beyond my wheel width and makes it easy to get close to things.
/ Landscape rake for BX, XB or standard #9
redharley said:
* I am sure a neighbor or two could use a hand.
priceing is about the same for 5ft xb and the 6ft standard at my local TSC,
*Want to watch out on this one.
~~~~~ Most insurance polices won't pay the second your tractor leaves your property.
I wouldn't go over a 5 footer for my BX1500 or BX 23.
I'm not familiar with A BX2250.
Is it anything like on the order of a BX 2230 or BX 2350?
== L B ==
Sorry for the typo guy's it is a 2230,some time's my mind gets way ahead of these finger's,Which by the way 40 years ago would have never thought typing would be something I would ever use.
/ Landscape rake for BX, XB or standard #11
I have a six foot Woods rake with wheel kit on my 2350 and it does a great job with r4 unfilled tires. Even pulling out the wet muck behind the horse barn!;)
/ Landscape rake for BX, XB or standard #12
If it is a 2230 would go with the XB, if you had the 50 series with the higher 3 point you may get away with the full size attachments. Have both the XB box blade and rear blade and I am happy with the size and weight match for the BX2230.
David
Kb7uns
Westendorf 8' Loader Bucket (A66408)
Westendorf 8'...
16ft Equipment Trailer (A65579)
16ft Equipment...
2013 Mercedes Benz GL 450 4 Matic AWD SUV (A64557)
2013 Mercedes Benz...
2020 CATERPILLER 326 EXCAVATOR (A65053)
2020 CATERPILLER...
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
2015 MACK GRANITE (A65643)
2015 MACK GRANITE...
