Landpride quick hitch?
   / Landpride quick hitch? #1
newtattoobob
Northeast Ohio
Kubota B2650, Kubota BX1850, RTV900XT Worksite, Kubota U17,1942 Farmall H, 1950 Ford 8N
Does anyone have any experience with the Landpride QH15 quick hitch? Will it fit with the telescoping lower lift arms? I have a Pat's easy change I removed from my L3400 but it will not fit on my new B2650 because of the telescoping arms. I asked my dealer and he said he has never even sold one of the QH15's, so he has no clue but said he will look into it. Anyone have any experience with this? Thanks
   / Landpride quick hitch? #2
I can not answer your question but if I may ask do you not like the Pats hitch?
   / Landpride quick hitch? #3
I have a QH-15 on my Kioti with telescoping arms and have no trouble with hook up.
I really liked the pats system, wish it fit on this tractor.
   / Landpride quick hitch? #5
I don't like the fixed style like the Landpride, all your implements have to be the right size to fit. My neighbor has the JD version of that quick hitch, the only implements that fit without modification are the ones made by JD.
   / Landpride quick hitch? #6
I have a QH15 on both my tractors and love them. The top hook adjust quickly and easily. I have a Bush Hog SQ172 cutter, Red Master II arena harrow, Land Pride tiller and landscape rake, and an off brand finish mower. I have not had to modify any equipment to use them.
   / Landpride quick hitch? #7
I have the LandPride QH15. I have several woods and land pride attachments. They all fit just fine. I like it a lot. I don't have telescoping lift arms on my B2920.
Thanks for all the replies it sounds like something I'm interested in. If I can find out for sure it will fit I will probably order one.
2022 Adams CLC-1013 Conveyor - New (A52748)
2022 Adams...
2015 MACK CXU613 TANDEM AXLE DAY CAB (A52141)
2015 MACK CXU613...
Farmall 460 Tractor (A50514)
Farmall 460...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
