Landini Powerfarm 105 HC (High Clearance) PTO engagement and draft issues
   / Landini Powerfarm 105 HC (High Clearance) PTO engagement and draft issues #1
featherstone
Rushford, MN
The vegetable farm I work on owns a Landini Powerfarm 105 HC for all sorts of field prep and harvest work. We also have the nearly identical McCormick high clearance unit (from what I understand same manufacturer, just colored red)
We have had recurrent issues with the PTO and three-point draft control on both tractors. PTO has an engagement lever to the left of the seat and a PTO clutch lever by the steering wheel. We engage the seat lever and then raise the clutch lever which makes the PTO turn. Increasingly this year the engagement lever would pop out of gear once we started to do actual work with the PTO. For example, when rototilling all goes well until the rototiller is lowered into the earth and then the engagement lever pops forward and out of gear. We have tried using wire to secure the lever and prevent it from popping forward with success some of the time, but this doesn't seem like it should be necessary. We also tried removing the linkage arm from the engagement lever, lengthening it slightly and seeing if that would engage it further, which worked at first, but no longer.
The three-point issue is one of implements jittering/bouncing around when the implement is raised/being raised. Since some of our equipment has humans as riders/on-board operators, this is highly unsafe. The bouncing at times is severe enough that the tractor driver is going for quite the wild ride. We have temporarily resolved the 3-point issue by disconnecting the draft control, but now the 3-point does not have the same range of lift.
Anybody have thoughts/experience? All help appreciated.
   / Landini Powerfarm 105 HC (High Clearance) PTO engagement and draft issues #2
Id guess the gears that engage the pro drive are damaged, the teeth get rounded off and will push apart under load, sliding the lever into neutral.
Our Landini always grinds a little bit when engaging pto, eventually the teeth wear away.
Not sure what to think about the hitch issue, only time ours might judder is when using the remote hydraulic valves.
49" X 79" EXPANDED METAL RAMP GATE (A51247)
49" X 79" EXPANDED...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
2021 John Deere 310SL Backhoe (A53342)
2021 John Deere...
2013 Caterpillar 950K Articulated Wheel Loader (A51691)
2013 Caterpillar...
2017 GENIE S-60X MANLIFT (A51246)
2017 GENIE S-60X...
