Landini 105 error code AL94
   / Landini 105 error code AL94 #1
Jack Miron
Montreal
Landini vision 105 year 2004
Any body have a idea to fix that intermitent error code AL94 on a Landini Vision 105 year 2004? It's seems from Float transportation hand brake switch. I remove the two micro switch, but never the less, that action those not fixe this intermitent error code. Some-time went this error code appear, the tractor can't move at all.
Anny one can't help me on this?
Many Thanks
   / Landini 105 error code AL94 #2
check the wire from the microswith to the resistrors pack, and from this to the controller.Everythings are behind the seat,but the wiring turn all around the cab. Then try to replace the resistor pack if the problem isn't fix. Also Reinstall the microswitch that control the mfd: now you can't switch off the 4wd.
Sorry for my bad language....
   / Landini 105 error code AL94 #3
Hi would like to know if this fixed the problem , as i have the same error on my vision 106 a2006 model
   / Landini 105 error code AL94 #4
around the 2006 year, some tractors start to have the park-lock microswitch in the lower part of the gearbox instead to have it on the right side of the seat... exactly, it's on the left side of the spring-on device of the mfd (just behind the mfd shaft starts). Check or replace it and the resistors pack also...
John Deere 310G (A42021)
John Deere 310G...
2024 VALLEY PIONEER QSP135 WHEELED MINI CRUSHER (A45046)
2024 VALLEY...
2013 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A44572)
2013 Chevrolet...
2020 BOBCAT S595 (A45046)
2020 BOBCAT S595...
Misc. Pavers (A42021)
2007 MACK CHN613 (A45333)
2007 MACK CHN613...
