Scook222
- Joined
- Mar 14, 2019
- Messages
- 143
- Location
- Northeast Louisiana
- Tractor
- Kubota L2501, Kubota M7040, RTV900XT
I started the installation on my third function today. I got ready to hook up the lines and realized that if they maxed a 9/16 orb to 1/2 JIC to put in the tank port of the block, you would only need one short hose to install the third function and you could reuse the pb hose to the tank. Everything would also mate up If you installed the factory rear remotes.
I went online and found this on Messick痴. It would work great because the third function would be first in line then loader then rear remotes/ backhoe except when you remove the power in off the loader to hook to the tank on third function, both hoses would need to be straight instead of a straight one and one that has a 90 degree bend on one side.
https://www.messicks.com/uploads/assets/380-152a_color_copy.pdf
Maybe I知 making this more complicated, but it would seem to be easier either way and a true plug and play system no matter which way the tractor was configured.
