Land Pride RB 1572 Rubber Edge
   / Land Pride RB 1572 Rubber Edge #1
TimP
Platinum Member
Kingsville, MD
B3000HSDCC
Hi All.
I have a Land Pride RB1572 blade and wanted to install a rubber cutting bade so it's easier on my asphalt driveway for pushing snow.
I can't find anything on the web as far as a rubber cutting edge from Land Pride.
Has anyone seen an OEM Rubber edge from Land Pride?
If they don't offer one, perhaps I can find a 72" edge from a 3rd party that I can install on the blade.
Thanks !
   / Land Pride RB 1572 Rubber Edge #2
99% of rubber edge's are DIY,,
go to Tractor Supply and get whatever suits you,,, :thumbsup:
   / Land Pride RB 1572 Rubber Edge #3
We use a rubber edge made from a tire tread on a scraper blade at work and the guys love it. The appeal there is that it rides over asphalt patches, gravel areas and the occasional fence post pipe stub without getting caught. We have a contractor for the main snow removal now, but we usually take care of the spaces between parked equipment, trailers and stored materials. The rubber is nice for taking care of the slush when the temps go up. It is several years old and hasn't worn down very much at all. Although it was a pain to cut I doubt that a piece of cow mat would have lasted this long.
I tried one here at home and took it off after a short trial. The areas where it's used here are smooth and without the obstructions and the rubber edge tends to skid over packed snow.
Thanks CADPlans and chim.
I appreciate the info !
Regards.
   / Land Pride RB 1572 Rubber Edge #5
I got a piece of horse stall mat from Tractor Supply, cut to 6-8 inches and installed between the cutting blade and blade--works like a charm!
Had to get some longer plow bolts as well.
Hi Jeff.
I have read a few posts a bout the horse stall mat at TSC. I have one near me and will stop in to check out the matting.
Thanks !
Portable Restroom (A54865)
Portable Restroom...
25 DUAL AXLE GOOSENECK TRAILER (A55745)
25 DUAL AXLE...
PALLET TOTE OF MISC (A58374)
PALLET TOTE OF...
2020 CATERPILLAR 306 CR EXCAVATOR (A52709)
2020 CATERPILLAR...
Set of 4 10-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 10-16.5...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
