Planters Land Pride No Till 3p606nt
   / Land Pride No Till 3p606nt #1
koamfps
Michigan
NH TN70DA & NH 2120
More than likely purchasing one next week.
Anyone had any direct contact/used one of these? Like to hear some pros and cons. (operating use issues)
   / Land Pride No Till 3p606nt #3
We have a 606TN pull-type and have been thoroughly impressed. What are your plans for it? Any reason you are choosing the 3pt vs pull-type? The biggest advantage to the 3pt are the maneuverability and trailerability. The wheels are just a hair too wide to drive the tractor and drill on a 102" trailer. I think the pull-type better follows the contours of the ground and is more effective planting while turning (in a large radius). The 3pt's have a tendency to push dirt with the openers leaving an inconsistent planting depth and and packing.
The 3 pt 606NT after a year of use has it's ups and downs. I do get occasional bare spots. When you lift at the end of a run to turn you lose some seed. Lastly changing the depth wheel SUCKS there has to be a better way! I plant everything from Clover to SunHemp to beans and corn to small grains the depth wheel is really my only complaint oh and the cost :)
For tight spots and trailer-ing. a 3pt is the way to go.
   / Land Pride No Till 3p606nt #5
I just purchased a used 606NT, although it's the tow model, not 3-pt.
Other than the hydraulic capacity needed to hoist the 3-pt, what minimum tractor size would you say is needed for pulling the 606NT up hills, soft ground, etc? We are considering a Deere 4520 (60hp), but it only weighs a bit under 5K lbs with loader and filled rears
   / Land Pride No Till 3p606nt #6
I actually have the same question. So I guess I will revive an old thread.
The website for landpride says the 606nt needs a 40 up minimum. Has anyone tried to pull with a 40 hp tractor?
I have a jd 990 and is claimed at 40 hp with an actual of 38.5.
(6) Bags of Tire Chains (A51573)
(6) Bags of Tire...
2008 Ford Taurus X SUV (A50324)
2008 Ford Taurus X...
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
City of Lakeland (A51691)
City of Lakeland...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A52748)
NEW 2024 LOAD...
