Land Pride FM2072 parts querry
   / Land Pride FM2072 parts querry #1
J H Musser
Holt, MO
1959 Ford 861 gasser (sold), Kubota F2560(Sold), Kubota BX 2230 Kubota B1700(Sold), Cub Cadet Z Force
I was able to recently purchase a used FM2072 Land Pride flail mower. It is missing the rod and flaps on the front side of the mower. It is my understanding that these flaps prevent objects from being blown back forward as the drum and blades turn toward the front of the unit and towards the rear of the tractor. I priced these flaps and they are about $25 each and I need a minimum of 10. I have seen hanging chain strips on the rear of rotary cutters which I suppose do the same thing. Does anyone see any problem with setting up the same type of system on this flail mower? It should be a lot less money for me. Thanks in advance for any suggestions anyone has.
anybody?
   / Land Pride FM2072 parts querry #3
This would be better asked in the attachments forum.
Maybe the mods can move it?
   / Land Pride FM2072 parts querry #4
AS long as the chains can't touch the blades when pushed under, they should work. Another common shield is heavy rubber mat or belting material.
Thanks for the belt idea, I see old firehose for sale occasionally on CL
   / Land Pride FM2072 parts querry #6
Check with your local welding shops. Multiple 3/16" rectangles of flat steel with a piece of pipe welded to the top should be easy and much cheaper than ordering parts. I was missing one shield on my NH 918 and cobbled it up in no time.
Also a great suggestion, thanks also
2008 AAR MOBILITY SYSTEM REFRIGERATED BOX (A52576)
2008 AAR MOBILITY...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
2006 CATERPILLAR 345CL EXCAVATOR (A51246)
2006 CATERPILLAR...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
