Land pride finish mower
   / Land pride finish mower #1
polaris
Central New Jersey
J.D. 4400
If anyone has a Land Pride air tunnel 72" finish mower how do you like it? I the quality of cut good, doe's it discharge the clipping evenly? How much grass does it cut per hour? My land is almost all open, level and gets cut quite often.
   / Land pride finish mower #2
I can't help you with the 72" model. I would've preferred the 72" model but I found a good deal on a 60" Air Tunnel Landpride (AT25-60), and I like it very much. Here is some information on my 60" model for comparison:
Clippings: The clipping distribution is excellent; however, I must add that I keep the discharge chute flipped up in order to get closer to obstacles. I'll have to mow with the discharge chute turned down one day to see how it does
Cut: I would rate it excellent.
Speed: I mow approximately 1 acre per hour with the 60". The mower could handle a faster pace, but the tractor ride isn't very comfortable at high tractor speeds.
Hope this helps.
Kelvin
   / Land pride finish mower #3
I recently purchased an 84 inch FARMKING rear discharge finish mower that I use with my 2000 TC40D Newholland tractor. I mow just the front area around the house on my farm, consisting of about five acres of level fescue grass. The cut is unbelievable and it actually looks like a golf course! Always use a mower-cutter that is at least as wide as your rear tires or wider, if you have the power to do the job, so that your tire tracks are mowed behind you in the same pass. I also use a 72 inch BUSHHOG rotary cutter on the same lawn ocassionally and it seems like it takes twice as long than it takes with the extra 12 inches on the FARMKING. /w3tcompact/icons/smile.gif Sam
"I love the smell of diesel in the morning."
Cummins powered 24V Dodge Rams rule!
   / Land pride finish mower #4
: polaris
I like my AT 2572, I added the anti scuf roller in the front.
If the grass is tall and open areas I will flip the chute open, does a good job blowing clippings way out there. Speed - I can mow the same patch with a JD 318 lawn mower but it takes 3 times as long.
DDT
DDT
The front roller you installed does it just bolt on or do you have to drill holes for it? Is it a Landpride part?
   / Land pride finish mower #6
polaris
I had to drill 4 holes for it but I have a older mower. If your getting a new one buy the option and the dealer will put it on for you. That roller is worth the $100 I gave for it, I don't think I'll ever wear it out.
DDT
UNUSED FUTURE CYHC HYD SIDE SHIFT FORKS (A51248)
UNUSED FUTURE CYHC...
Tailgate For Pickup Truck (A53117)
Tailgate For...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2003 Chevrolet Silverado 3500 Crew Cab Pickup Truck with Gooseneck Hitch (A51692)
2003 Chevrolet...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
TAKEUCHI TL12V2 SKID STEER (A51246)
TAKEUCHI TL12V2...
