Land Pride FDR 1660 rear discharge mower
   / Land Pride FDR 1660 rear discharge mower #1
check 6
South Texas
BX 2680. Front bucket, grapple, pallet forks, box blade aireator 008-5 excavator ZD 1211 mower RTV 500
Does anyone have this unit. Thinking about it for my BX 2680 as a rear mower is easier to attach and take off than a belly mower . My tractor is a back up mower to my ZD 1800 but occasionally I need to mow large areas ie a 2200 ft long grass runway and thus the question about the FDr 1660 Thanks
   / Land Pride FDR 1660 rear discharge mower #2
LP is a good brand...I've got the 1672 rear discharge unit...great mower.. If I'm not mistaken, even the belts are Kevlar...Shrps74
   / Land Pride FDR 1660 rear discharge mower #3
I have had a 1660 for about 8 years. It works fine. I went thru a few belts recently as I waded into some scrub oak. I should have switched to my bush hog. Be sure to buy the front anti scrape roller. I had problems on uneven grind until I added one. Also change the clips that hold the wheels on to bolts.
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
Set of AG R4 Wheels and Tires (A53472)
Set of AG R4...
RHINO DB150 LOT NUMBER 76 (A53084)
RHINO DB150 LOT...
Kubota KX91-3S2 Mini Excavator (A52377)
Kubota KX91-3S2...
New/Unused 7ft Stainless Steel Work Bench with 20 Drawers (A51573)
New/Unused 7ft...
