Land Pride 2572 Grooming Mower Quick Attach
/ Land Pride 2572 Grooming Mower Quick Attach #1
Dicky
Hi all -
I just bought a Land Pride 2572 Rear Grooming mower for my JD 4300. It does not appear to be at all compatable with my Speedco quick attach hitch. I have found away to hook up just about every other implement, but the mower seems impossible. Any one else have this problem? Any solutions?
Mower is much less usable without being able to use the quick attach.
/ Land Pride 2572 Grooming Mower Quick Attach #2
Well I don't know what problem you're having, but do you need to turn the pins in from where they are? Would that solve your problem? On some implements this is a fix, but I've never used the speeco hitch, so I don't know.
John
I guess the main problem is that the drive line hits the bottom of the quick attact hitch while going over a dip in the yard.
/ Land Pride 2572 Grooming Mower Quick Attach #4
Okay, trying to visualize it without owning one.
It's possible that if you moved your hitch arms to the other set of wholes it probably has, the arms will hang lower and may solve the problem.
I'm talking about where the upper arms come down and connect onto the hitch arms. Mine has two holes, some have only one.
Try moving the attachment on both sides to the other hole and see if that helps.
John
EDIT: If you need a picture to understand where I'm talking about, I'll get you one of mine. It's sometimes hard to explain exactly with words.
J
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61573)
2010 Ari Hetra...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
1991 BMY 6x6 Wrecker (M936A2) (A62613)
1991 BMY 6x6...
14ft Flatbed Truck Body (A59228)
14ft Flatbed Truck...
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
