Rear Finish Mower Land Pride 1560 help!
   / Land Pride 1560 help! #1
tobypineo
Bronze Member
Fort Kent, Maine
Kubota B3200
Hi folks, thanks for reading. I can't figure out what's wrong with my LP 1560...the middle blade is spinning freely. The side blades are turning by the belt, as they are supposed to. The middle one just "freewheels". The nut is TIGHT! Can't budge it. I don't understand why the blade has enough clearance to rotate freely...ideas are welcome. Fwiw, I have no idea how old the mower is, bought used, it's all rusty, nothing pretty about it, but it has been mechanically sound until now. Thanks for any ideas.
   / Land Pride 1560 help! #2
Loose pulley/broken key at the top of that spindle?
We can't see it. You have to look closer to see what is turning and what isn't.
Nothing else is turning. The pulley, top nut, grease cup, washer...nothing. I can wiggle the blade a little up and down, seems like it must be loose
   / Land Pride 1560 help! #4
Blade bolt and washer are tight but blade turns independent of anything else? Blade contact area is worn.
2008 Jeep Patriot Sport SUV (A50324)
2008 Jeep Patriot...
2005 FORD F650 4X2 XL SUPER DUTY FUEL/LUBE TRUCK (A51243)
2005 FORD F650 4X2...
DHE 38-7 7 SHANK ALL PURPOSE PLOW (A51243)
DHE 38-7 7 SHANK...
Aluma 7712H Tilt Trailer (A50514)
Aluma 7712H Tilt...
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE MINI...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
