Land plane parts source recommendations?
   / Land plane parts source recommendations? #1
pls1911
Aledo
Cat
I'm gathering parts for a landplane/grading scraper for skid steer use. The steel is no issue.
I need to identify "best" sources for serrated blades as well as solid cutting blades.
Titan seems to be the best solid blade source I've found (I have had good blades from them) .
I have inquiries out for serrated blades bo no responses to dates.
Also what's the "best value" source you have found for ripper shanks?
   / Land plane parts source recommendations? #2
Go to your county road commission shop and see if they have old grader blades or plow blades. Should be cheap or free. May have to use a plasma cutter or grinder to make the serrated blade
2008 Volvo XC90 Multipurpose Vehicle (A51694)
2008 Volvo XC90...
2007 Hino 268 Truck, VIN # 5PVNE8JVX72S50442 (A51572)
2007 Hino 268...
John Deere 5203 Tractor (RIDE AND DRIVE) (A50774)
John Deere 5203...
PENDING SELLER CONFIRMATIONS (A52577)
PENDING SELLER...
2014 Hitchai ZX470LC-5B Excavator (RIDE AND DRIVE) (A50774)
2014 Hitchai...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
