Land Leveler / Land Plane Advice
   / Land Leveler / Land Plane Advice #1
FreedomFamilyFarms
Auburn, IN
Kubota B2710, Toro Z Master Commercial
I have about 1/4 mile of driveway in NE Indiana running a 27 HP Kubota 2710. I already own a box blade a sand scraper blade but I’m seriously considering a land leveler. I won’t add rear remotes to this machine for TNT and I’m no professional operator so I feel like the land leveler is the right tool to maintain the drive.
I’d like to run it often enough that the mechanical tillage will eliminate weed growth without herbicide. I have a solid #2 limestone base and have been topping with Duraberm (crushed steel mill slag).
Curious if anyone else is using a similar setup or any other experiences. Leaning towards either the ETA model or the LandShark counterpart.
   / Land Leveler / Land Plane Advice #2
I have a crushed stone (A23) driveway. There's quite bit of fines in my driveway and it gets pretty hard once it dries out. In the spring before the driveway hardens up, I have used a back blade with scarifers to level out pot holes and dig up weeds. I added gauge wheels to my back blade and those make a big difference for leveling. The length of a land plane should give you the same effect if not better. If there's no major pot holes, the Harley rake does a great job of getting out the weeds and turning some gravel over. Once it dries out in the summer the driveway gets too hard for a back blade and I imagine a land plane as well but I have not used a land plane.
I called the gentleman that delivers the Duraberm and he uses a Land Plane on his driveway so I ordered one. Decided to give the Independence series from Homestead Implements a try. Weight is about the same as the best selling Land Pride at my local Kubota dealer.
2009 Subaru Outback AWD SUV (A50324)
2009 Subaru...
2018 Nissan Titan Crew Cab Pickup Truck (A50323)
2018 Nissan Titan...
2015 Kia Sedona Van (A50324)
2015 Kia Sedona...
2014 Ford E-350 Cargo Van (A50323)
2014 Ford E-350...
MARTIN - SET OF 12 COULTER MOUNT MARTIN ROW CLEANERS (A52748)
MARTIN - SET OF 12...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
