lagoon
   / lagoon #1
mechanic
missouri
Has anyone ever had your lagoon get to much water in it. The over flow pipe is at the wrong angle and is not releasing any water. I told the builder that but he says that the level will start going down when the weather lets up. I have seen it drop quite rapidly during the summer months. Seem like we can't keep enough water in it during the hot months.But we are still 3 months away before hotter weather gets here. The builder says that the pipe should draw out water even if it is sloped wrong. I don't believe that.
   / lagoon #2
Not sure what you mean by saying it's sloped wrong. Is the outlet higher then the inlet? Is there water flowing out of the outlet side?
A properly designed pond (I think a lagoon is a pond) will have a spillway large enough to handle the worse case weather conditions. There is no such thing as a pipe big enough for this. A pipe is good for most situations if that's what you like, but a pipe is never a spillway.
If you get more water into your lagoon/pond then the pipe can keep up with, where will the extra water go? Over the dam?
Eddie
   / lagoon #3
Up here a lagoon is for depositing waste, and you don't want anything draining out of it.
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A53421)
2007 Godwin Pumps...
2008 Ford F-550 4x4 Dump Truck with Lift Gate (A53422)
2008 Ford F-550...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
2018 Ford F-250 Reading Enclosed Service Truck (A55788)
2018 Ford F-250...
2019 GENIE GR-20 ELECTRIC VERTICAL MANLIFT (A52705)
2019 GENIE GR-20...
Craftsman ZTL 7000 Mower 42in mowing deck Parts/Project (A55301)
Craftsman ZTL 7000...
