Lack of Power, Feguson TO30
   / Lack of Power, Feguson TO30 #1
VulturesRow
Oklahoma
'52' Ferguson TO-30
Got a lack of power on my TO30. Coughs and sputters when gas is applied.
Checked the plugs, they are good. Fuel system *appears* to be clean and in working order. Is there anything else I should check? Carb adjustment maybe off? Don't know........
Was a strong running old tractor last season and the first mow of this year...............and for some reason, all of a sudden, does not want to get up and go. Starts up just fine, but sputters quite a bit when at idle and all the way through full power.
FYI......just recently replaced the water pump but do not think that could be the cause of the problem.
Any thoughts/ideas would be greatly appreciated!!
   / Lack of Power, Feguson TO30 #2
To run properly, the engine has to have a GOOD SPARK (FAT AND BLUISH-WHITE, the color of lightning) at the RIGHT TIME and the cylinder must be filled with the PROPER FUEL/AIR MIXTURE.
I'd start by checking the spark.(More problems occur with the primary ignitin circuit then with the carburetor!) Pull the center wire iur of the distributor cap, hols it ear a good ground and str a start. You should see a FAT, BLUISH-WHITE SPARK, the color of lightning. If it's a spindly blue redish-bluish, or yellowish spark then there's a problem in the primary ignition circuit (battery to key switch to coil to distributor points to ground). The points may be dirty, oily, corroded (from lack of use over the winter), or improperly set. The distributor shaft/bushing may be worn. The condensor may be bad. There maybe high resistance in the key switch (yes they do go bad), the coil my be failing, there may be hih resistance in the primary circuit wiring (loose or dirty connection, corrosion, etc. Poor grounding ofthe battery or the distributor is a possibility. SO these need to be systematically checked out and by a process of elimination , not 'throwing parts at it", the cause determined and remedied.
If you have the requisite spark (FAT AND BLUISH-WHITE), then check the carb adjustment needles. The big knob on the carb is the main jet adjustment and should be around 1-1/4 turn out from full in. I should never be less that 1 turn full out on the Z block Continentals because thats too lean and you can burn exhaust valves due to a lack of charge cooling from evaporating fuel. The idle air mixture control screw inward for enrichment and should be about 3/4 to 1 full turn out. T
here shuld be adequate fuel flow to the carb. remove the plug at the bottom of the carb fuel bowl. With the tank vlave full open, the fuel should CONTINUOUSLY gush out the bottom. If it dribbles or is intermittent, then you have a fulel delivery problem. There is a screen in the fuel connection elbow onthe carb, Check it for crud and then work your way back to the tank. Check the filter above the sediment bowl. make sure the fuel line is not kinked or bebt, etc. Make sure the vent hole in the fuel cap is open. if you still cant't get fuel flow out of the carb, the tank vale is clogged or the float valve passage is clogged or there is so much crud inthe fuel bowl that the float ca't drop. The carb has to come off to check that.
Go through these checks sytemtically and you'll find your problem. Resist the temptation to start throwing parts at it and find the root cost of your problem and fix it. It's a good learning experience and it the cheapest way to fix your tractor.
Found the problem. The main jet idle needle has broken off from the knob. Trouble is I have had no luck finding a replacement. Even the carb overhaul kits do not contain this part. Now the 8N carb kit has one. Will that work for my tractor? The only other option I have seen is buying a new carb but don't have 200 burning a hole in mu pocket right now..........
   / Lack of Power, Feguson TO30 #4
I don't know what "...the main jet idle needle..." is. There is a main needle and an idle air needle and they are separate. Any decent carb kit for the Marvel-Schebler TSX458 will have new needles. I've never see one break before. Somebody must have really reefed them down. Go to the Yesterday's Tractor website and then to the parts section. and you'll find waht you need. I think a regular kit is about $25+shpg.
2002 Sterling M7500 Acterra Lift-All LA04C51 51ft Insulated Forestry Chipper Bucket Truck (A50323)
2002 Sterling...
Vermeer 502 Towable Stump Grinder (A50774)
Vermeer 502...
2014 Chevrolet Spark Hatchback (A50324)
2014 Chevrolet...
2008 MAGNUM TRAILER LIGHT TOWER TRAILER (A52472)
2008 MAGNUM...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
1991 HEIL FUEL TRANSPORT TRAILER (A52472)
1991 HEIL FUEL...
