la402 problem
   / la402 problem #1
david whick
my loader will only move up regardless of using the up or down position. What is the problem?
   / la402 problem #2
have you checked all the connections? IE on the control value quick disconnects?
any kinked hoses?
how many hours?
Later,
J
   / la402 problem
I have checked connections, kinks, etc. Pressure builds up on lower right line,[female] not in the control valve. I have bled it off several times with the same results. I even bled the line and lowered the bucket and no matter which control I use [up or down] the bucket will rise.
   / la402 problem #4
have you tried to swap the those hoses with the bucket control hoses?
If it works then-- It is likely to be a control valve problem..
J
   / la402 problem #5
Have you moved any hoses on the loader valve? You may have the hoses mixed up.
   / la402 problem
my problem was the quick connect above the line that was loading up. It was not allowing the fluid to complete its flow.
(4) 250/80-15 Solid Forklift Tires (A52384)
(4) 250/80-15...
2018 Ford F150 XL (A52384)
2018 Ford F150 XL...
2017 Chevrolet Express LT Passenger Van (A51692)
2017 Chevrolet...
INMY Manual Landing Gear (A51692)
INMY Manual...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
