LA402 lube
   / LA402 lube #1
Anonymous Poster
Epic Contributor
I've had trouble getting one of the grease points on my LA402 loader to take lube. 11 of them take grease easily, but that 12th was a struggle. Finally, a few days ago, I got brave, and decided to fix it. I remove the pivot bolt, and tapped the pivot out far enough to grip it with a pliers (with jaw protectors), and rotated it 180 degrees. After putting it back together, it takes grease real good now. I don't know if there is a grease groove on the pivots..I didn't take it all the way out, but I suspect there must be. Also, I noticed that several of the pivot retaining bolts were quite loose..even with the nylon insert lock nuts installed. I tightened all of them, and will add that to my checklist on each 50hr maintaince. Those bolts/nuts are a uncommon size..11MM socket and wrench fit exactly.
   / LA402 lube
Thanks for the heads up on that. I just got my B2910 w/ 402 Loader. That is a good thing to know. Let you know if I have that problem.
~Dave~
2001 Ford Ranger 4x4 Ext. Cab Pickup Truck (A51692)
2001 Ford Ranger...
2014 Dodge Avenger Sedan (A51694)
2014 Dodge Avenger...
2016 Freightliner M2 106 Ambulance (A53422)
2016 Freightliner...
John Deere Motor Grader (A52377)
John Deere Motor...
2012 Peterbilt 388 Sleeper Truck Tractor (A53117)
2012 Peterbilt 388...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
