LA302 FEL o-rings
/ LA302 FEL o-rings #1
John762
Tennessee
Kubota/7610
Does anyone know where to find the o-ring that is inside the quick coupler female fitting on the hoses that lead from the hydaraulic cylinders on the loader and connect to the 4 position control valve? I have tried my dealer where I bought the tractor and they could not find one on their parts diagram for that loader and they had some spares but none of them matched. The parts guy said I would probably have to buy the coupler. I told him I would look around and only do that has a last resort. I have found one in the proper diameter but thicker that would fit but not allow the coupler to completely couple. Any help would be appreciated.
John
/ LA302 FEL o-rings #2
There is nothing in the books for this by part number. We do match them.
/ LA302 FEL o-rings
can one be matched that has a chunk torn out of it? At the auto part's stores I have tried they only had something close and after 2 times neither one has worked. I have one last source to try that makes hoses and gaskets hopefully this will work. I will probably take a good one off of the other hose to try and get a better match.
john
/ LA302 FEL o-rings #5
I had the same o ring problem with my 302 fel, i was lucky and actually found a match in my junk o ring box, keep searching,there has to be a match out there somewhere.
/ LA302 FEL o-rings #6
Near my shop i have a company that sells nothing but O-rings. The owner is verrrry knowledgable. Check your phone book for industrial suppliers.
John Deere 4040 Tractor (A64047)
John Deere 4040...
(6) SHANK RIPPER BEDDER W/AUTOMATIC SHANK TRIP (A64280)
(6) SHANK RIPPER...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
UNUSED MOWER KING-AGT SAII100 (A64281)
UNUSED MOWER...
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
2017 Ram 5500 Bucket Truck (A63689)
2017 Ram 5500...
