La272 loader on a B7500
   / La272 loader on a B7500 #1
Buckeye Chuck
Columbiana Ohio
Massey Ferguson GC2300 JD210 GT
Does anyone know the spec.'s of a LA272 loader? Basicly it's lifting limit also a LA302 loader. I'm looking at two different B7500's with different loaders.
Thanks in advance.
   / La272 loader on a B7500 #2
Thanks in advance.
One interesting note. You likely realize this, but those numbers are not random but are kilograms. Convert to pounds by multiplying by 2.2 for a rough estimate. You probably already knew that.
   / La272 loader on a B7500 #3
Model LA272 LA302 LA352 LA402
Maximum Lift Height (To bucket pivot pin) in. 69.7 69.5 69.7 82.3
Clearance w/Attachment Dump in. 51.6 52.0 51.6 65.5
Reach @ Maximum Height in. 26.8 25.4 25.0 26.0
Maximum Dump Angle degrees 45 45 45 40
Attachment Rollback Angle degrees 24 24 24 26
Digging Depth at Bucket Leveled in. 3.1 3.2 3.1 5.3
Overall Height in Carry Position in. 45.3 45.7 45.7 47.0
Material Bucket Width in. 48 48 50 54/60
Lift Capacity (500mm forward) lbs. 495 555 670 760
Lift Capacity (Pivot Pin) lbs. 685 770 925 1060
Lift Capacity (Bucket Center) lbs. 595 660 770 882
Breakout Force (500mm forward) lbs. 1003 1120 1336 1618
Raising Time to Full Height w/out Load seconds 3.1 2.5 3.1 3.2
Lowering Time w/out Load (powerdown) seconds 2.4 2.0 2.2 2.4
Attachment Rollback Time seconds 2.1 1.7 2.6 2.4
Attachment Dumping Time seconds 1.8 1.5 2.0 1.9
Rated Flow GPM 3.6 4.4 4.4 6.4
Rated Pressure psi 2000 2200 2000 2000
Boom Cylinder Size in. 1-1/2 1-1/2 1-3/4 1-3/4
Bucket Cylinder Size in. 1-1/2 1-1/2 1-3/4 1-3/4
   / La272 loader on a B7500 #4
Well, my post doesnt look that great and includes 2 loaders you did not ask about, but basicly the first 2 numbers in each field are for the LA272 and the LA302 respectivley.
hope this helps.
James K0UA
   / La272 loader on a B7500 #5
Buckeye Chuck -
Lift capacity to maximum height (bucket bottom mid point) is 270kg (595#) for the LA272 vs 300kg (660#) for the LA302. Maximum lift height to pivot pin is 1770mm (69.7") for the LA272 vs 1765mm (69.5") for the LA302.
   / La272 loader on a B7500 #6
Thus, 272 kg times 2.2 equals 598 lbs
And.. 302 kg times 2.2 equals 664 lbs
Since the rest of the world uses kg not lbs, Kubota labels their loaders with this scheme. The label itself tells you. In the US, we just aren't used to seeing this and oft times don't see the scheme is right there in front of us.:D
1 guard rail (A49346)
2011 FREIGHTLINER CORONADO(INOPERABLE) (A50854)
2011 FREIGHTLINER...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
New Holland TS6. 120 Tractor (A50322)
New Holland TS6...
TAKEUCHI TB210R EXCAVATOR (A51242)
TAKEUCHI TB210R...
197359 (A50458)
197359 (A50458)
