Front-End Loader la211 loader and BX 2750d
   / la211 loader and BX 2750d #1
kidsdad5
Burnt Hills, NY
Kubota BX2200
looking to replace my 2000 BX2200 with another used BX. I’d like to keep my 2750d snowblower and 2751 quick hitch front mount. Can anyone tell me the range of model years in the BX series I can consider so I am able use the same attachments? Thanks
   / la211 loader and BX 2750d #2
I have a BX2230 with a snowblower 2750d. Also bought a snowblower off a BX2360 (I think). I will need to change the input shaft to the front hitch to work. Not sure of driveshaft lengths. Should know more in a month or so. Jon
   / la211 loader and BX 2750d #3
Unless I’m mistaken, you can use that blower and front hitch all the up to the current BX models.
However with the 80 series, they did change the way the hood opens and it will interfere with the front hitch. The hood will only open about half way. The other things that will change is the hydro couplers are now flat face, so those will need swapped.
That being said, with the 80 series they came out with the new 4 point front hitch and a new style of blowers for it.
One last thing, you may have to change the shaft in the hitch depending on the model it’s going on. I think there are only two different lengths of that shaft. Check with a dealer as I’m not positive in that.
UNUSED FUTURE 40" HYD TILT MINI EXCAVATOR BUCKET (A51244)
UNUSED FUTURE 40"...
H & S High Capacity Hayrake (A50515)
H & S High...
2015 Mitsubishi Mirage Sedan (A50324)
2015 Mitsubishi...
Pequea HR10 Rotary Rake (A50774)
Pequea HR10 Rotary...
Heritage / Woods RD 72 3 pt Finish Mower (A50515)
Heritage / Woods...
